Doug___
| 03/26/2003 12:59 AM |
| I was wondering if anyone had any feedback to give about the reliability/performance of the in-cab remote control system that can be used with Rancho 9000X shocks. Thanks |
tmf___
| 04/04/2003 12:43 AM |
I have the in cab remote in my 86 blazer. It is pretty cool, real easy to install, and pretty straight forward. the only problem I ran into was that I do a lot of surf fishing, so I drive on the beach a lot. On one of my shocks sand had a tendancy to get under the seals which made it leak air. It was no big deal you just have to unscrew the air hose and clean and relube the seal and it worked fine after that. That was the only problem I ever had with them. Just make sure you lube the seals really well, and make sure your hoses aren't near anything hot. Also when you order them make sure you ask for some extra air hose. I only had about 6 inches left over when i was done. So if you make a mistake your screwed. Hope this helps
TMF
Doug at 3/26/2003 12:59:15 AM
