brandy
 Bone Stock Posts:29
| 02/25/2008 9:12 AM |
| my husben and i rebilt a 350 c |
primetimek5
 Lift & Lockers Posts:537
| 02/25/2008 1:22 PM |
HELLO & WELCOME.
what year & model first?
how does it idle?
any smoke coming from the exhaust?
if so what color?
what does the exhaust smell like? gas?
location? some people on the board might be close enough to do a drive by. |
rick p. |
brandy
 Bone Stock Posts:29
| 02/26/2008 3:57 PM |
| 91 chevy 3/4ton 4x4 5.7 L no smoke idle smooth timing set very high if timing set to factory truck very slugish & pops &sputers though throutle body exhust no bad smell |
primetimek5
| 02/27/2008 6:18 AM |
| sounds to me the timing order is off. |
rick p. |
brandy
 Bone Stock Posts:29
| 02/27/2008 7:37 AM |
| could the cam have any thing to do with the way it back fires we also have vortec heads on there with a tbi i dont know the lob lift but it is a rv cam hope you can help its makeing me crazy !!! also what do you mean by timing order . |
primetimek5
| 02/27/2008 12:11 PM |
| sorry i will explain as soon as i get home. im gust to busy at work to get in depth.
rick p. |
brandy
 Bone Stock Posts:29
| 02/28/2008 6:09 PM |
| well what happen!!! we did a tone up to the truck today it still runs slugish but it seem to run a little better . hope to here from you soon. |
primetimek5
| 02/29/2008 11:49 AM |
did u replace the cap, rotors & wires?
there is a splecial timing sequence for the cap & motor. make sure thats is correct.
sorry ididnt get back w/ you but, had to take one of my clients to the sours game last night.(go spurs!!)
i will post later w/ firing order. |
rick p. |
brandy
 Bone Stock Posts:29
| 03/01/2008 10:03 AM |
| yes we replaced the spark plug,wires,cap,roter,aircleaner,pcv.valve ect.thats ok hope you had fun at the game . i hope to get the other heads of the spare truck i have and get them to a machine shop maybe i have a bad valve and maybe the fact that they are vortec head on there now and i need to put it back to factory.talk to you latter!!! |
brandy
 Bone Stock Posts:29
| 03/10/2008 4:41 PM |
| well im going to start to work on the other engin this next week hope to here from you soon to see if there is anything else i can do to help my problem talk agian latter !!!! |
brandy
 Bone Stock Posts:29
| 04/06/2008 10:34 AM |
| i was hopeing to here from you soon my post has not been answerd in a while i tock the heads off of the old truck now i need to go get the head and valves checked is there any thing i should look for or any special tighing order other than what is in the chiltion book you said the timing order might be of can that take place other than the spark plug and the distribitor cap can the timing chain have anything to do with it can you give me the specs on it just to be sure that its right !!!! |
| 05/04/2008 10:11 AM |
Hi Brnady - our site was hacked by some scumbag hacker a while back. Unfortunatley, as part of that hack, the original subject that you posted was cut off. Could you please reask the question and describe the symptoms that you are having one more time?
thanks, and sorry for the inconvenience.
brandy
 Bone Stock Posts:29
| 05/04/2008 1:45 PM |
| well for starters we rebilt the engine it is a 350 tbi 4 bolt main 5.7 liter the engine has vortec heads on it new timeing chain,lifters,cam am not sure on the lobe lift but when you step on the gas it back fires in to the tbi we took it to a shop and they set the timing anout 8 to 10 degres passed top dead center . because if they had it set to facory seting it blew out black smoke and fire out the tail pipe and wouldnt run at all .it is just very slugish like there is no power what i was wondering is if the vortec heads would have any thing to do with that or the cam or the valves we have very good compresiom in every one of the pistons hope you can help in about 3 weeks i will have time to check mor into her problems
thanks alot for checking into this !!!!! |
