Subject: AMSOIL Synthetic Motor Oil Provides Maximum Fuel E
heathmrktgUser is Offline
08/22/2008 12:22 AM
Image Uploaded To Thread:
[img]http://www.4x4review.com/discussions2/uploaded/heathmrktg/200882201658_yahoopic.jpg[/img]
Rising fuel costs have motorists searching for anything that will improve vehicle efficiency. Vehicle manufacturers, under pressure to meet more stringent EPA regulations, are recommending lower-viscosity oils as one way to improve efficiency. AMSOIL 100% Synthetic Motor Oil (ASM) features a special low viscosity formulation that combines maximum fuel economy with maximum wear protection. Maximum Fuel Economy
AMSOIL Synthetic Motor Oil is designed to maximize energy efficiency for improved fuel economy. Its light viscosity properties reduce drag and its uniform molecular structure helps it fl ow more freely to lower friction between metal surfaces. Anti-friction additives are included to further improve energy efficiency. Superior Wear Protection
AMSOIL Synthetic Motor Oil is a shear stable formulation with a high viscosity index. It provides excellent viscosity film strength to separate metal surfaces and contains robust anti-wear additives for the best possible engine protection.
Reduced Oil Consumption and Emissions Volatility (burn-off) occurs when oil gets hot, causing high oil consumption and emissions.
AMSOIL Synthetic Motor Oil has a very low volatility rate, making it excellent at controlling volatility-related oil consumption and emissions. Extreme-Temperature Performance
AMSOIL Synthetic Motor Oil resists thermal breakdown better than conventional oils. It is heavily fortified with detergent and dispersant additives to prevent sludge deposits and keep engines clean. And unlike conventional oils,
AMSOIL contains no wax. It stays fluid down to -65°F for improved cold-temperature oil flow, reduced bearing wear and easier starting while maintaining superior high-temperature protection.
Request you free information http://www.allpurposeoil.com
Mobil1 Vrs. Amsoil Click HERE to find out the Truth http://www.allpurposeoil.com
Forums > Vendor Showcase > Vendor Specials, Product Announcements, etc. > AMSOIL Synthetic Motor Oil Provides Maximum Fuel E
